G4 network
Dksrottie2
I'm looking at getting a Samsung S20+ 5G phone and want to know if my 4G plan will work with it or if I need to either upgrade my plan or look for a lesser phone upgrade.
@Dksrottie2
It should just work fine with PM. My friend and member have the older Samsung A11…works great.
will13am
@Dksrottie2 , don't forget the VoLTE whitelist check.  The phone is VoLTE capable, however the Telus whitelist is rather restrictive.
https://www.telus.com/en/support/article/how-to-use-volte
hairbag1
@Dksrottie2
that cellphone will work perfectly on PM network.
@Dksrottie2  It will work fine on both networks no need to change a thing . Get and enjoy the new phone
