01-23-2022
12:28 PM
01-23-2022
04:03 PM
computergeek541
Hello Community,
Me and a few friends of mine love all the discounts with Public Mobile, we take every opportunity to save money with this wonderful new company (new to us).
I had a friend switch to Public Mobile in December 2021, during a special discount period, and had them enter the unique 6 character referral code, xxxxxxxxxxxx, from my account into their sign-up form, hoping for a discount. Unfortunately, the friend referral discount was never received. We cannot call customer support, we are left here losing our opportunity for a precious discount! Can anyone help?
Thanks.
01-23-2022 03:12 PM
@Gr8Service99 wrote:Hello Community,
I had a friend switch to Public Mobile in December 2021, during a special discount period, and had them enter the unique 6 character referral code, ------, from my account into their sign-up form, hoping for a discount. Unfortunately, the friend referral discount was never received. We cannot call customer support, we are left here losing our opportunity for a precious discount! Can anyone help?
Thanks.
So, if your friend used your referral code, then you should be seeing the last four digits of their number(s) in this area.
Go on your SELF SERVE account, choose the MY Rewards button.
Then by clicking on the arrow pointing to the right, which will open up the list and the arrow will then point down.
Rewards referral list:
IF you don't see the phone number listed, then they entered the code incorrectly or something did not apply right.
Your friends are the one that will need to submit a ticket to Customer Support (CSA).
Then can reach them by two methods found here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
01-23-2022 12:40 PM - edited 01-23-2022 12:44 PM
Sharing your referral code on the public forum is not cool.
Click the down arrow on the upper right of your message and please immediately edit out that number.
EDIT: your friend will have to contact customer support. The best way to share your code with friends is to copy and paste it into a document (or via SMS), and ask them to copy and paste that into the activation field where it's to be entered. If they attempt to decipher the characters there will likely be errors between the Oh's and the I's and these zeros and the ones
01-23-2022 12:38 PM
@Gr8Service99 : The suggestions of you contacting the CSA's isn't really correct. The new customer is the one to contact them.
01-23-2022 12:34 PM - edited 01-23-2022 12:36 PM
You might have entered zero instead of “O”.
Just contact a PM CS_Agent to have them check.
PM should use a stroke across 0 for zero to avoid confusion.
01-23-2022 12:32 PM
You can send a private message to CS_Agent with your account details and the PM phone number(s) of the person/people you referred. It's also possible that your friend(s) will have to contact them to get this issue rectified.
01-23-2022 12:31 PM
Did your friend get a $10 credit? Did you write that code down for them to use at activation? Maybe the O and 0 got reversed or confused.
