Fresh latest model SIM
bstorzie
I am having network trouble and want to try a new SIM.  Can i get new SIM sent to me?
hi @bstorzie
what kind of network problem you have?  you tried Reset all networks on the phone?  Also, try the sim card in another phone.  We still people with sim tray problem on the phone itself more than a sim card problem
but if you need a new one, buy a PM physical sim card from Telus or Koodo or Mobile Klinik stores or via Amazon:
 Telus or Koodo or Mobile Klinik store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
Then you can login My Account and to go Profile page to update sim card number
slusagm
sim card usually good and rarely fails
if you can show PM that the problem might be the sim card, they will be willing to send you one for free
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
Chalupa_Batman
You could but I would not recommend getting it from Public Mobile as there is a Canada Post strike so you may not get it for a very long time. Try these links for faster service.
If you need a physical SIM, Amazon sells them. Click on AMAZON for the link.
Or locations near you that have a SIM. TELUS STORES
Side note, you need to know that NOBODY here works for Public Mobile. We are all customers like you.
