11-23-2024 09:01 AM
I will be going to Europe in April. Is there a plan or add-on that will cover me in Europe.
If not any suggestions.
Plans
11-23-2024 11:24 AM
@Allan7 wrote:I will be going to Europe in April. Is there a plan or add-on that will cover me in Europe.
As stated below already, no need for me to repeat. Just adding this link to help you further.
https://www.airalo.com/united-kingdom-esim
Here you can get eSIM if your phone allows it to use your phone in Europe. You can download an app like TextNow and pick a local phone number to where you live now and have folks call that and you'll be able to get free calls to where ever you are.
11-23-2024 09:48 AM - edited 11-23-2024 09:49 AM
You can also use WhatsApp on wifi for free calling and texting. TextNow app may also work.
11-23-2024 09:08 AM
@Allan7 No sorry PM only has roaming in the U.S. / MEX for Eruope your best to get travel sim like airalo or get local SIM card in your destination and it’s super cheap in Europe for cell plans anyways
11-23-2024 09:05 AM
PM has no service in Europe
use travel esim or buy Europe data sim instead
