06-23-2023
07:19 PM
06-24-2023
12:15 AM
computergeek541
Hi, your transaction log does not match my usage. All my minutes are used up. Is it possible someone has hacked into my account?
06-23-2023 07:31 PM
@CA9 Please have support investigate for you
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
06-23-2023 07:28 PM
if you have concern, message support and show them what you have that you think is wrong.
06-23-2023 07:25 PM
*do not see
06-23-2023 07:24 PM
No I fo not see those numbers.
06-23-2023 07:22 PM
@CA9 do you see some numbers ending with 4001? if so, those are VM calls. Please note calling from your phone to check VM will count towards you outgoing minutes
Also, calls are always round up to the next minute
