02-16-2018 02:41 AM - edited 01-04-2022 03:32 PM
I know it's moot now, but I had to reset my password for Community using the "Forgot username or password" link. So I went to change my password but I had trouble logging in still. Turns out that I couldn't remember my username. I eventually figured it out, but perhaps you should have an option to also request the username in addition to having a password reset, not just password reset.
The link does say " Forgot username or password" but the username is not currently retrievable.
Thanks!
04-29-2019 05:15 PM
We also need a fix for this. My wife forgot her username and there is only an option to change her password. That doesn't help when you don't know your username. I hope a moderator will chime in on when there will be a fix for this.
04-13-2019 06:58 PM
Man, they STILL didn't get that fixed? My post was over a year ago.
Good thing I've autosaved my login for all devices.
04-13-2019 04:27 PM
This still hasn't been fixed. I had the same problem. It was very frustrating since this is the ONLY avenue of customer service help, and there was no help to allow me to get help.
02-16-2018 02:47 AM
02-16-2018 02:43 AM - edited 02-16-2018 02:43 AM
@Mystery Are your referring to your self-serve account username? If yes, that is your email address.
