Forgot my email address need moderator
sachiin
Hi, I don't remember my email address, I need a help from moderator. I remember my pin.
RossN
@sachiin you need to contact a customer service agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
type  request email   change
2. alternatively you can private message them here
Timer
@sachiin
 submit a ticket to Customer Support Agents.with SIMon here,
or by private message CS_Agent  to change email and set new password.
Outdoorsman
@sachiin
hi to cnange your self serve email you nneed the help of a service rep
There are two ways to contact a customer service agent , open a ticket through Simon here https://publicmobile.ca
Or  private message them here
HI @sachiin   if you want to try, you can try to put in your exiting email addresses in Forgot password link on My Account login page , then see if you get any reset password instructions in the email
if that doesn't help and you need to open ticket with CS agent, then :
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
