Flip Phone that can only take incoming calls
timbo3344
Hello!
Is it possible to get a plan or change a setting where I can get a flip phone on a plan that CAN'T make outgoing calls?  It can only accept incoming calls.  Even preferably only incoming calls from certain numbers?
Thanks
@timbo3344 wrote:
Hello!
There isn't any such account setting at Public Mobile.  Your best option would be to get a smartphone and to get a smartphone and install an app that has the option for parental restrictions to be set.  I have also read about devices in the past that could only make outgoing phone calls to preset numbers.
hairbag1
@timbo3344
no PM plan has any of those "options".  Not aware of any network that does either.
hi @timbo3344 you can't really.. the only manual way is to get the $15 plan and use up the 100 outgoing minutes at the beginning of every cycle
