09-05-2022 03:01 PM
I have an account with Public Mobile and paying for two active sim cards. I can’t seem to find one of my sim cards in my account. What do I do?
09-15-2022 12:09 PM
@darlicious @RossN Definitely a newish glitch. Think it was triggered when PM began allowing customers to use email addresses from Koodo accounts AND to reuse deactivated PM account usernames. 🤔
09-05-2022 07:58 PM
Thanks all:) didn’t expect all this help! I will try your suggestions and see what happens
09-05-2022 05:39 PM
use browser from computer,/clear cache/cookies/use one page inPrivate mode,
or safari on private mode, then tried Reset Password which email you did set up an account, there 2 different email, each account has one email.
09-05-2022 04:49 PM
@darlicious yea no kidding 😭
09-05-2022 04:47 PM
Lol... Yes but you get paid much much much less than minimum wage!
09-05-2022 04:46 PM
@darlicious is that like a walmart greeter 😂
09-05-2022 04:42 PM - edited 09-05-2022 04:43 PM
Oh.... Public Mobile is so glitchy that even though this is never supposed to happen you have managed to activate a second SIM card and account using the same login credentials as your original account. As a result the second account is hidden behind your original account and you cannot log into it because it has the same login credentials as the original account even though they are completely separate accounts.
You need a new email preferably not an email alias because that can cause its own problems then contact customer support to change your email on the second account that you had created you will then be able to log into it after resetting the password. Contact customer support you can use the links already provided by our community greeter @RossN .😁
09-05-2022 03:42 PM
"Added another sim card"? This would not have been possible using those words. Did you sign up that second account in a store?
09-05-2022 03:40 PM - edited 09-05-2022 03:40 PM
@2Butterflies The second number would have needed a separate self serve account and different email, although you could use an email alias so that all emails come to your main email address. Your payments can be made with the same CC and that's what you've been doing.
You'll need to submit a ticket using the links provided earlier to activate the self serve account for the second number.
09-05-2022 03:36 PM
I originally I set up an account for myself, then through my account, using my visa, I added another SIM card. Payments are going through, but for some reason, I don’t see it when I sign in to my account
09-05-2022 03:07 PM
Did you activate these accounts in a store? If so did you create login accounts for each?
09-05-2022 03:04 PM
@2Butterflies hi you must have 2 emails for 2 sim/accounts,if you don't remember one
you need to contact customer service agent to fix things for you
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
