Finding 2nd account
JungleZac
I pay for two accounts (me and wife), however only my account is showing up when I log in. Where can I find her account?
7 REPLIES 7
CountyDownIeUk
2 PM accounts = 2 email accounts = 2 separate logins
#2 email could be an alias.
Yummy
At PM each account is unique. You cannot have family account to manage multiple accounts from one log in.
You will have to find email/password she used to create self-serving account. If she never did that before, now is the chance!
darlicious
@JungleZac
Did you use the same email for both accounts? If so then access is hidden on the customers side. You will have to contact customer support with a separate email for your wife's account to be added by the CSA.
Did you use an email alias for your wifes account? Or thats an option for the above scenario.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here   ....for additional member supplied info.
@JungleZac  - try registering for an account for your wife here using a unique email:
https://selfserve.publicmobile.ca/self-registration/
If having issues, submit a ticket to CSA for assistance to get the email changed or one set up for her.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
schinz13
It's under the separate email you used when opening the account, as far as I know it won't allow the same email to have more than 1 account, when doing my partners I was forced to use a second separate email for the activation
@JungleZac   PM My Account is one login for one phone line.  So, if you have 2 accounts (phone numbers), you must have used 2 different My Account logins.
If you activate both instore, there is a chance the second account has not been created yet.  Try to click the "Create Account" Button from the login page
If you are unable to create the account for your 2nd phone, maybe it was created before, open ticket with PM to sort this out.  You can message them  here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
iliketotalk
@JungleZac hi somewhere you must have a different account with a different email that's the only way you can have 2 accounts here check through your/her emails
