Failed number port
Tapooty
I received this message trying to port my number over to new public mobile esim.
no one has called me. Do I keep waiting or is there a number I can call:
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided.
2 REPLIES 2
@Tapooty
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
SourDude1234
Hi @Tapooty
If no one reaches you, then please private message an agent using the following link
