Failed Plan Change at Renewal Date
brandyn_marx
Hello! A couple of weeks ago, I set my plan to change from a $25/month plan to a $40/month plan on the renewal date (July 23rd), but looking at my account page, it appears this did not work. It also shows that I've consumed all 1,024mb of my $25/month plan for this period (July 23rd to Aug. 22nd), but that literally isn't possible, because I've spent all of today connected to wifi. Is this an issue with the account page, or did my plan fail to change at the renewal date?
Hi @brandyn_marx .  You are the thr only one with this complaint.  could be because the new My Account upgrade and deleted all the scheduled plan changes
Open ticket with CS agent and see if they can help
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
dust2dust
Can you login on a different device like mobile if desktop or desktop if mobile. Or use a different browser. Or use incognito mode. Just to see. Also check that second date up top to see that it says until August 22 and not still July 23.
MrSpock
@brandyn_marx hi yes there are odd things happening lately
you will need a customer service agent to help fix this
you will need to open a ticket, to speak to a customer service agent    Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
