12-27-2023 11:12 AM
I just created a public account and the code to verify my account won’t send to my number
12-27-2023 11:35 AM
If you did not receive or cannot receive your 2FA code by SMS - Click on: ‘Didn’t get a code’ and you will get more options. Chose email.
12-27-2023 11:23 AM
Hey @Joel_Thiessen
Try this.
Can’t get the 6 digit 2FA code to your phone?
First, sign into your account at www.publicmobile.ca and use the email you signed up with and the password. If it asks you for a 6 digit code, it will say at the top left CONFIRM YOUR IDENTITY.- Enter the 6- digit code sent to *********. But it’s not working!!! As you see by the screenshot below, 1. Click the This is a trusted device. 2. Didn’t get the code? Click on that.
Then, the next window that pops up is this.
Click on Send email. Here it will send you the 6 digit code to the email you registered with. This step is very important. Do not just copy and paste. Enter each digit using your keypad.
You should now be able to get into your account.
Created by Chalupa Batman
12-27-2023 11:15 AM - edited 12-27-2023 11:15 AM
@Joel_Thiessen Have you put the PM SIM card in phone yet ? It should send code that sim . If not please submit ticket with support to help
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
