3 hours ago
2 hours ago
yes, the new phone these days can easily handle that
Remember, you might want to go to the sim. manager and setup the default sim to use for voice or data
give us the type of your phone and I can give you steps how to do
3 hours ago
Hello @Melinda_herv
Of course. As long as your phone can handle both eSIM and a physical SIM card, you sure can. You'd just have to set which one will be the primary and which is the secondary. Just know this. If you are on the phone with the primary, if someone calls the secondary it will go straight to voicemail. It will not ring. Hence the reason it's may be better to have a secondary phone instead.
3 hours ago - last edited 3 hours ago
Yes, it your phone supports dual SIM like iPhone 11, you can have one regular SIM linked to account/phone number and eSIM linked to another account/phone number
