New subscriber
Pradalserey
I can’t send or receive text or phone calls
Andy85
Hi @Pradalserey,
Do you still have service on your old SIM/cellphone provider?
Chalupa_Batman
Hello @Pradalserey
Have you rebooted your phone? If so, have you tried your SIM card in a different phone? Sometimes the SIM card needs to be reprovisioned in a different phone to wake it up sort of speak. And if then it works, put it back in your phone.
slusagm
if you cannot send and receive calls and text, it is account setup issue.  You need to ask PM to check
you won't be able to open ticket with Chatbot, so message PM using this link
HALIMACS
@Pradalserey
Did you transfer your number from another provider?
Did you reply "YES" to the port authorization request from the prior provider, within 90 minutes of receiving the text with your prior provider SIM card in the device?
Try rebooting device, resetting network connections, and toggling airplane mode on/off.
