2 hours ago
Still receiving some messages on old phone with public mobile sim though number was ported to another provider. I am receiving most messages on new phone with new service. Once my number was ported I could not access public mobile account to ensure subscription was cancelled. What can I do?
2 hours ago
Public Mobile does not provide over the phone customer service. The toll free number is entirely automated.
2 hours ago
My god an actual person number.. thanks!
2 hours ago
you should be all fine with PM account got cancelled
you can also confirming calling 1-855-4PUBLIC and enter your number. The system should not be able to find you account and it confirms your account cancelled
2 hours ago
Ok, that phone just died so will try once it gets some charge. It is an iPhone so what you said about imessage makes sense
2 hours ago - last edited 2 hours ago
Once you ported out, your account will be canceled, you will be no longer able to check your account
You may need to ask CSA by submitting a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
2 hours ago
can you make phone calls??
if not, the text you got likely from iMessage or RCS. Go to the setting of the app and disable it.
or if you want to test it is not from SMS in PM network, remove the PM sim, leave Wifi on and you should still get those text because those iMessage/RCS works on Wifi
2 hours ago
Did that. Receiving texts on new phone since Thursday but received one on old phone today. I can't get back in to account online to see if subscription cancelled. Once the number was ported, I could not get in to account so I figured that meant it was cancelled
2 hours ago
It’s weird, once porting is completed, the public mobile SIM should be deactivated, it not supposed to work anymore.
try to restart both the old phone with public mobile and the new phone with the new service, it may resolve your issue
