3 hours ago - last edited 3 hours ago by computergeek541
2 hours ago
thanks
2 hours ago
Hey @D101
Couple questions. Have you been a long time customer or did you just start? If you just started and you were with another carrier before, you may need to do a network reset on your phone. If that doesn't work, then you may need Public Mobile to reset your network on their end. This is how you reach them.
To submit a ticket with CS Agent using this Chatbot link
Type Customer Service and follow the prompts. If you are having any issues, here is a direct link by sending a private message
3 hours ago
thanks for the reply, tried that, still doesn't work
3 hours ago
Restart your phone, try again
