08-22-2024
02:04 PM
08-22-2024
02:54 PM
computergeek541
I switched from Virgin Mobile on Tues. 20th. (xxx-xxx-xxxx). I used an e-sim setting as it said my phone (Motorola G) was compatible. I can not send or receive text messages. Phone calls are okay.
Please help.
08-22-2024 10:33 PM
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
08-22-2024 02:05 PM
