Adding digital sim card
RJC4
Is it possible to add a digital sim to a Iphone to use Public Mobile and keep the existing other supplier. In other words use 1 phone for 2 different supplier service.
12 REPLIES 12
self solution removed
RJC4
Thanks, I need your help, I'm trying to purchase a eSim, having trouble finding price and how to order it. I don't know if it's my age but I find the Public Mobile website quite difficult to navigate and yet I'm not a rookie. Maybe we should explore simplifying access to all information. It seems many emails are members having trouble and I find that disturbing. Thanks
RJC4
Thank you, you are right. I confirmed on my Iphone SE 2
@RJC4
The iPhone SE 2 has 1 nano SIM and 1 eSIM and not a dual eSIM.
RJC4
Will verify if Iphone SE 2 supports 2 sims. Thanks for your reply
RJC4
Presently have Iphone SE 2, I think it may support 2 sims. Will verify. Thanks for you reply.
RJC4
Good to know, thanks
RJC4
Thanks for this info.
EB0
@RJC4
Yes, iPhone XR-iPhone 12 support one eSIM and one regular SIM, iPhone 13 or later support 2 eSIM or one eSIM and one regular SIM
@RJC4
If you have dual eSIM then yes. If you are a new member, the eSIM is free with a new activation.
If you are an existing member, you will need to purchase a second eSIM.
Dunkman
@RJC4
Two eSIMs?  Or one eSIM and one physical SIM card?
If the iphone is 13 and later, then the iPhone would support two active eSIMs at same time.
Meow
IF your phone supports two SIMs and IF your phone supports eSIM then - Yes.
