Esim
Ellie61
I purchased a new phone and sim card. I'm an existing customer. The site said the esim downloaded. I didn't receive an email with a qr code.
hi @Ellie61 you don't need the QR code, the app is supposed to install it for you.  Check the Sim Manager or Settings ->Cellular screen, it might be there already and just need to be enabled
@Ellie61
If you are an existing customer already, you need to download the PM app on your new phone.  Then login into your account.  In the profile section, purchase eSIM and then eSIM should install on your new phone.  If you already purchased the eSIM before, subsequent eSIM purchases should be free.
@Ellie61
Contact a CS_Agent to help you by typing in Submit a Ticket then Contact on the Chat icon for a agent to help you with the QR code.
ORNGNBLK
@Ellie61   Check your phone settings, see if the PM eSIM is there and available to set as primary.
Ellie61
The won't activate public mobile
