Esim
snoopyviola
I need to buy a new Samsung esim compatible phone. Does anybody know for sure which ones are for sure compatible..... was told by a seller that wouldn't know until I activate it because of country of production....
Chalupa_Batman
Just to add to everyone's comments, there is a place called Mobile Kilink. Here's the link of all Samsung phones they sell.
Mobile Klinik
There, they would be able to tell you what will not only work on Public Mobile but what will have eSIM abilities. Plus, if you go into your Rewards section within your account, click on this link and you can get some discounts from there.
https://myrewards.publicmobile.ca/en/catalogue/CntstEl-MKCPO
Dunkman
@snoopyviola
Here is the official list:
https://www.publicmobile.ca/en/get-help/articles/volte
Does not cover all VoLTE compatible phones though.
Newer Samsungs made for the North American market are usually fine.
If you have a few preferences, just let us know and we can offer some personal experience.
Phil_Adelphus
@snoopyviola  was told by a seller that wouldn't know until I activate it because of country of production....
Does this mean you are looking to get a phone model not intended for the Canadian market?
@snoopyviola
All the newer Samsung phones are compatible so any S20 or newer or Note 20 or newer or A35 or newer or Z2 flip or newer and all fold phones.
Only way to know is to check if there is an Add eSIM in the settings.
What model are you looking at?
Sansan
Google should give you the correct information.
However, I have the samsungs s20 FE i bought from Koodo here in Canada and it is not eSIM compatible.
