Esim troubles
Terry1973
Well i did a boo boo when trying to activate my esim and now my origonal service isnt working. It is in sos mode. I got an email stating i cud get the sim card reactivated but dont know how
Priority
Was your Original service also with Public Mobile before switching to e-SIM or did you just Port in from another provider?
Usually with in the hour @Terry1973  but there only open from 8am 10PM EST
Terry1973
How long does it usually take to get a response
Terry1973
Yes i just did. Ty
@Terry1973  please submit ticket with support to help you
private message   To CS_Agents click
HI @Terry1973
which one was the original service? with PM using physical  sim?
for your eSIM, you should get an email from PM with the QR code. Scan it using your phone and you can install it yourself
let us know if you can find the QR code on the email.  If not , you will need to submit ticket with PM agent:
