02-22-2024 02:34 AM
I dont know whats going on but i might need a new esim and i cant confirm my public mobile account for full access without access to eSim
02-22-2024 05:00 AM
If your number is ending in 362?
Just enter the 2FA code so you can access your account through Eversafe ID.
02-22-2024 04:52 AM
It just shows me this
02-22-2024 04:47 AM
I would suggest you login to your account on the app or online and check in the Profile section that will show your current number.
Also reboot your phone and see if your number shows up on your phone.
It could be just a glitch.
02-22-2024 04:39 AM - edited 02-22-2024 04:40 AM
Yes did get an email but when I paid for new plan/sim/account I used the confirmation screen link to activate esim.everything looks like it was working so I don't know why it says unregistered sim and no mobile phone number
02-22-2024 04:35 AM
Did you get an email from PM with the QR code for the eSIM?
You can scan the QR code to your phone and reboot your phone
02-22-2024 02:41 AM
Have you tried rebooting phone or resetting network settings? If still issues contact an agent with the link below:
During business hours, they strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
