Error
jj46
Trying to sign up for a week. Paid the subscription, but keep getting errors with getting service on my phone.
We encountered an error processing your request.
This may be due to a system error, please go back to the previous page and try again. (Error Code: XXX)
Everytime i log in it keep saying, subscription not activated.
Can't get any help through the support tab
jj46
Yes, paid already. Deleted app and reinstalled. Same problem. "Subscription not activated..." Have reached out to customer agent.
jj46
yes, app.
"Subscription not activated, Something didn't go right..."
hi @jj46 paid already?? were you using app to subscribe?? if not, download the app and use the same login and try.  Or if you already using app, uninstall and reinstall and try
if it does not work, please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
hairbag1
@jj46
are you using the required PM app or website to activate the new account ?
@jj46  Have you tried to activate on the app not website ? All activation need the app . If same use this direct link for support
send  a  private message   To CS_Agents
