10-16-2019 08:43 AM - edited 01-05-2022 07:35 AM
Hi,
when I click on My Rewards button I get the message “error occurred while loading reward details”.
Any ideas?
Thanks!
10-16-2019 11:43 PM
@cemilro wrote:Hi,
Any ideas?
Thanks!
Public Mobile Self Serve is always doing strange stuff. If you try later, it'll probably work.
10-16-2019 08:49 AM
@cemilro, I get the same response on two of my accounts. I don't know why this happens. However, it does not affect the accumulation of rewards. I just cannot see running totals. If it bothers you, you could ask the moderators to look into it. I don't really care unless it interferes with rewards accumulation and usage. The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. Refer to the following knowledge base article for additional information on the moderator team.
