03-22-2022 06:17 PM
got this error after paying and signing up what do we do now
03-22-2022 07:26 PM
@wendy21 wrote:got this error after paying and signing up what do we do now
@wendy21 - if you were charged for the activation, insert the Public Mobile SIM card and do the below:
*turn off your phone, then reboot
*perform a reset network settings on your device
Do you have any services?
Then try to log into your account: https://selfserve.publicmobile.ca/Overview/
If you have services and you can log into your account, then you activated your account.
If no services, then submit a ticket with Public Mobile Customer Support as methods provided already in this thread.
03-22-2022 06:24 PM
Another customer just experienced this, you can check it below or this link
As it explains why you are getting it and why you shouldn't try to activate again.
03-22-2022 06:23 PM
Do not try to activate again! Check your payment card to see if your plan amount has been charged.
Try SIM in some other phone. That will determine if it is your phone hardware issue.
Usually 821 is missing/incorrect porting information. Your SIM card will need provisioning to your incomplete account activation. Send a private message to customer support with "incomplete activation" in the subject line and explain in detail your issue. Once the CSA sets it up correctly you will be able to finish your self serve account set up.
