01-26-2026
09:10 PM
02-22-2026
06:19 PM
computergeek541
I purchased the plane for 20 and the eSIM is not working it says contact agent.When it asks for 2 step verification code no code gets sent. What can I do to get my known to work
01-26-2026 09:12 PM
can you double check if the PM eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
but if it is not there you will need to ask PM support agent to help, you can submit ticket by direct message:
01-26-2026 09:12 PM
