Emergency calls
Awheeler0428
My phone switched to emergency calls. Can't login into my account either. Made my payment on the 16th for my monthly plan. Very frustrating, anyone else having issues?
15 REPLIES 15
Good thing to check @HALIMACS , but I think OP could not log into their account...although maybe they got in since their last post a few hours ago.
@Awheeler0428
Have you checked for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
You could also try manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily); does this help with services?
And to be sure, check if your phone is not blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
edit - whoops, you did the test with another SIM in your phone, and it works...scratch out above then.
@Awheeler0428
Check this:
Login to your self serve and click change SIM card under the my profile section.
Note the last four digits represented on the account for the registered SIM card.
Now physically take the SIM card out of your device and look at the last four digits of the SIM card.
Do these two sets of numbers match?
dust2dust
Maybe another way to ask about the credit card is, did you recently deal with problems or fraud on your credit card?
@Awheeler0428   don't wait , open a ticket with PM.  That does not sound right.  Hope it is not your account got compromised
Also, did you reverse any Koodo or PM charge on your credit card?
Awheeler0428
It rings when I call it from another phone and I have my login automatically saved and it will not log in. Also will not let me reset my password either….
@Awheeler0428 wrote:
Yes I’ve been using it until around 1pm today and then it went to emergency calls only. Makes no sense as I did not get a text or anything if it was a port out….this is a little ridiculous if you ask me
HI @Awheeler0428  You cannot login My Account?  was that because you forgot the login id and password or you just suddenly cannot access My Account even you are 100% sure the login?   As I said, I just worry, your number got ported away or SIM fraud.
Try to call yourself from a landline to see if it goes to your voicemail or it says no service
Awheeler0428
That number does not work anymore and it is definitely a public mobile issue as I tried the sim in another phone and it does not work, I also tried another sim in my phone and it works.
Hi @Awheeler0428 how long you were not able to use the service?  Were you able to still use it right after April 16  when you renewed?  I hope you are you victim of SIM fraud or your number didn't got port away
I would open a ticket with CS Agent and have them to check your account and advise, message them at:
@Awheeler0428
It sounds like your account is suspended.
How did you make your payment? Are you on AutoPay?
There was a glitch with AutoPay on April 1.
You should definitely contact a CS_Agent to look into your payment and your login issue by SIMon Chatbot or private messaging on this Community page.
Contact a CSA.
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
Awheeler0428
dust2dust
Did you possibly see a charge from Koodo sometime along the way and did a chargeback on that?
dabr
@Awheeler0428    What plan are you on?  If you're on the $15 plan, perhaps the outgoing minutes (100) have been exhausted and you would need to purchase the 500 minutes for $5 to enable calling.
@Awheeler0428 if you use a landline and call 1855-4PUBLIC, then enter your number, what does it say?  Just want to confirm your account is either Active or Suspended and we can further advise
JK8
@Awheeler0428
Try rebooting and reinstalling SIM card. Can you try your sim in another unlocked phone?
