Emergency Calls Only
04-29-2021 09:32 AM - edited 01-06-2022 02:36 AM
So I activated last night, worked with a moderator to port in a number and all was good. Service was fine last night. Woke up to emergency Calls Only and I've since missed a phone appointment. Been trying to communicate with mods all morning with no response.
Service
04-30-2021 07:57 PM
I had a similar problem recently.
What worked as a work-a-round was to eliminate LTE in the phone network settings.
So try:
LTE/WCDMA/GSM –> WCDMA/GSM
or
restart
04-29-2021 07:43 PM
This message means that the phone is connected to a network that will not allow the service to be used and can either be because of a network outage, being connected to a different network than TELUS, or if the service is not provisioned properly.
You COULD try the lost/stolen trick to reset your service. From your self service account:
- enable the lost/ stolen feature,
- log out,
- wait 5 minutes,
- log in and take it off,
- log out,
- restart your phone.
If this fails to work, try reaching out the Moderators again, specifying that this is a multiple request for the same issue which remains unresolved. They've got to make this right for you.
04-29-2021 07:42 PM - edited 04-29-2021 07:44 PM
@danduf1981 wrote:No. I was using it on a previous carrier just fine. It came straight from Google.
Hi @danduf1981 if the phone is neither blacklisted nor reported stolen, then it might be the SIM card is not inserted or seated properly, this risks causing phone to only allow calls to 911. Ensure SIM card is securely inserted into the slot. It may not hurt to remove it and re-seat it. Make sure it's correct side up.
Here is an article that might help you
How to fix a cell phone that says Emergency Calls Only
Please keep us posted
RosieR
04-29-2021 07:24 PM
@danduf1981 are you up and running now?
If not, try a Reset of your Network Settings.
04-29-2021 10:09 AM
04-29-2021 10:08 AM
Did you buy your phone brand new? Any chance its been blacklisted?
https://www.devicecheck.ca/check-status-device-canada/
04-29-2021 10:04 AM
@danduf1981 : Well they do need to quit for the night 🙂 I've read of a few times where mods are on and doing things late in the night. But I would still start a new ticket.
04-29-2021 10:01 AM
MODs usually reply within few hours depending on number of inquiries. Just be patient a little bit 🙂 I know it is important to you but nothing can speed up their response.
Did you try removing/inserting SIM, rebooting phone, toggle plain mode on/off? Did you try your SIM in another phone (if you have it handy)?
04-29-2021 09:57 AM
I've done all of that. The person I was working with last night just stopped responding to my messages as well.
04-29-2021 09:56 AM
@danduf1981 : Did you start a new ticket? They will have decided that problem was done. This is a new problem.
Can you try the SIM in another phone? Maybe even just restart?
