01-20-2022 04:50 PM
I do not remember the email address used for my self-service account. How can i get this info?
My Account
Service
01-20-2022 07:42 PM
@afarrell87 wrote:I do not remember the email address used for my self-service account. How can i get this info?
@afarrell87 - How many options could there be?
Do you know if you even registered for a Self Serve account? You may not have i you activated in-store or with CCS.
To register for an account (if you are a current customer) you can sign up here: https://selfserve.publicmobile.ca/self-registration/
01-20-2022 05:30 PM
01-20-2022 04:58 PM
HI @afarrell87
You can try to use Forgot Password link and guess the email you might have used. If you got the correct one, it will move to Step 2 , but you still need to answer a security question after
if you are really unable to reset it that way., open ticket with PM using Chatbot
click on the Bubble on the lower right or directly at : https://publicmobile.ca/chatbot.
Follow these these to get to ticket open page quicker:
- type: Forgot log in information
- Click "Contact Us"
- Click "Click here to submit a ticket"
- you will then direct to another page to open ticket.
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
01-20-2022 04:57 PM
You will have to contact CSA. Get ready to provide bunch of personal info when asked to authenticate your identity.
Send them private message as per link provided in another post. Response time is 1-2 hours or less (if they like you 😋).
01-20-2022 04:52 PM - edited 01-20-2022 04:52 PM
Try putting public mobile in your search feature of all of the email addresses you have access to.
01-20-2022 04:51 PM
Please send a private message to CS_Agent with your account details so they can look this up for you.
