02-10-2023 11:44 AM
I would like to transfer from my Mom’s email to my email, and I was told I had to create my own personal community account in order to do so, so I have now.
02-10-2023 11:52 AM
Only ONE email can be associated with ONE PM account.
You cannot have mom's email on her and your PM account.
Otherwise, only agent van change your emial.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private message might take longer.
02-10-2023 11:47 AM
HI@lilaf it is doable, but you need to have Pm cs agent to help to change it
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
02-10-2023 11:47 AM
To change email you need supports help each account can only have one email
Watch for reply top of page to the
Right ( envelope image )
