07-17-2026 09:48 AM
My phone died completely. I have no access to my email as I thought I was being smart using the "strong" randomly generated passwords for everything. Wrong!!! I've purchased a new phone, but can't log in to my actual PM account. Please help!
07-17-2026 09:52 AM
hi @Melissadee
did you try login on both PM app and the browser?
if you are using the PM app, please note that the phone keyboard will turn capital on for the first character, so, when you type a small case character , it changed to capital. Before you submit the password, unhide the password and check if the case is correct
but if you are still unable to login, ask PM agent to reset the password for you. You can submit ticket by direct message:
07-17-2026 09:51 AM
Ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
