03-31-2022 08:41 AM - edited 03-31-2022 08:43 AM
Hi There,
I just purchased an Easyfone Prime a1 with a Public Mobile plan... Here's what's going on...
SMS working
Web-browser working
MMS not working... can't send or receive picture messages
Here are my network settings
Username: Blank
Password: Blank
Access point: sp.mb.com
Gateway: 74.49.0.18
Port: 80
Rename: Public mobile
DNS: 009.009.009.009
Network Type: HTTP
Does anybody know how to fix this?
04-20-2022 07:19 PM
Thank you. Works now!
04-20-2022 07:18 PM
Hi, thank you, it worked.
I chatted with the chat bot and it gave me the instructions to set up the APN.
I had previously neglected to set the homepage to the aliasredirect site given. Including that in the settings makes it work!
Thanks!
03-31-2022 11:13 AM
was data turned off? I am assuming that fixed your issue?
03-31-2022 09:08 AM
For MMS to work DATA has to be ON even though data will not be used.
03-31-2022 09:03 AM
@EZF_guy this is a flip phone and should works on PM without issue
check the knowledge from previous post
03-31-2022 09:00 AM
Maybe try rebooting your phone. Network reset of phone.
This phone does not seem to have 4G bands, only the necessary 3G bands.
Check the APN Settings of the phone.
One correct version:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
03-31-2022 08:44 AM - edited 03-31-2022 08:53 AM
Ensure data is toggled on.
Try manually switch into 3G Network.
Also make sure any RCS services, (such as Android chat or iMessage) is disabled.
EDIT: @EZF_guy Also try removing the SIM card, then reinserting it. If none of this helps, contact support staff as they may be able to reprovision the SIM:
There are 2 ways to reach customer support agents:
You’ll see their reply in your Community private mailbox in the envelope to the left of your avatar.
