E sim didn't install
Dannhb1968
My phone restarted while the E SIM was Installing on my phone.  So now my account. Is partially activated but I do not have my e sim which I paid for already.
2 REPLIES 2
HI @Dannhb1968
Please try to reboot your phone first
then try to Reset all networks
If that does not work,  please submit ticket to CS agent at:   https://widget.telus.tiia.ai/publicmobile/publicmobile.html
@Dannhb1968  First try to reboot the phone and reset network setting see if that helps , otherwise contact support
  • while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking >>>>>>>>here.
