11-01-2020 10:32 AM - edited 01-05-2022 03:59 PM
11-01-2020 02:20 PM
@Dessie wrote:Does public support dual sims card
I'm uncertain of what you're asking by this. Yes, you can use any compatible phone you wish, including as others have said, dual SIM card devices. However, if you're asking if you're allowed to have 2 different SIM cards with the same phone number, the answer is no.
11-01-2020 12:13 PM
@Korth: I was trying to be short inserting as little as I thought necessary for my "fix". Of course the phone has to be compatible to the carrier. The "unfixed" post said any.
11-01-2020 12:00 PM - edited 11-01-2020 12:02 PM
@Anonymous
The phone has to be compatible with the carriers. It it's incompatible then you have to get a different phone. (This isn't an issue anyways unless your phone was intended for non-Canadian markets, your phone is a decade obsolete, or your phone was carrier-locked to only work with one carrier.)
The carriers don't have to be compatible with each other.
11-01-2020 11:20 AM
@Helpershelper wrote:
Yes, you can use any 2 compatible carriers of your choice with a dual SIM. Which compatible carrier does not matter, they'll work.
Fixed it for ya. 🙂
11-01-2020 11:11 AM
Yes, you can use any 2 carriers of your choice with a dual SIM. Which carrier does not matter, they all work.
11-01-2020 10:55 AM
Phones can support (or not support) dual-SIM.
The SIM cards themselves - along with the operators which issued them - can't do anything to enable or disable other SIM cards in the phone.
11-01-2020 10:55 AM
Yes, I have a dual sim phone. You would need to select which sim you want to use when making a call or using data.
11-01-2020 10:54 AM
@Dessie wrote:I have dual sim from a previous carrier does public mobile supports dual sims
Absolutely. But Public Mobile is only a SIM. No eSIM. You can have two accounts or one and another account from elsewhere.
11-01-2020 10:51 AM
Hello @Dessie ,
According to this thread, it looks like YES! 🙂
https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Dual-Sim-potential/td-p/497829
11-01-2020 10:35 AM
