10-10-2019 08:28 AM - edited 01-05-2022 07:30 AM
Has anyone been successful using blackberry dtek 50 with PM looking to change may parents over just want to make sure there hardware will not have any issue (radio frequency look like they area compatible)
11-10-2019 02:13 AM
My first public mobile port was to DTEK50 for my wife. Phone was formerly on the SaskTel network, so it should be the same model as Bell in the rest of Canada. It works swell, and even supports HD Voice calls to other Telus/Koodo/PublicMobile customers.
10-23-2019 08:26 PM
Yes this phone is great and works fine on Public Mobile.
10-10-2019 10:06 PM
@JW2 wrote:I will need to find out if it's unlocked
Just call bell with IMEI number handy and ask for the code
It would be best to insert non bell sim like public Telus o or Fido to have the exact error message.
10-10-2019 08:20 PM
I'm in Ontario
10-10-2019 08:19 PM
10-10-2019 08:13 PM
@JW2Since Public Mobile uses Bell towers out East, the phone should work fine provided it is unlocked.
10-10-2019 08:11 PM
Bell is the previous provider it is a Canadian version of the dtek
10-10-2019 03:35 PM
Definitely should work!
10-10-2019 03:33 PM
@JW2 careful about different worldwide variants. Some models have multiple frequency configurations.
10-10-2019 03:28 PM
As @totalUser said, try using your Public SIM card with their phone, if you're with Public mobile.
BTW, if your parents aren't too computer/self-serve savvy Public mobile might not be a great fit for them. Some people are content paying more each month to have small issues taken care of by an easily available representative.
10-10-2019 11:29 AM - edited 10-10-2019 11:37 AM
Hi
Are you with public? Can you test your sim inside? If not do you have any friends or colleagues who wouldn't mind doing it? You can also take the phone to koodo or telus store and ask them to try it
In general i would trust the information about the frequency, but since you are doing for elderly you want to make sure that they don't have to tweak apn settings or anything like that as well as getting puk code after they have switched, you want to do that before.
Btw who is the previous provider?
10-10-2019 08:37 AM
According to https://willmyphonework.net/ it should be compatible with PM.
10-10-2019 08:31 AM
@JW2 wrote:Has anyone been successful using blackberry dtek 50 with PM looking to change may parents over just want to make sure there hardware will not have any issue (radio frequency look like they area compatible)
Yes it will work well.
https://www.kimovil.com/en/frequency-checker/CA/blackberry-dtek50
