Dropped calls
JBonnie
Occasionally the call drops when we answer our calls, or even worse says the number is no longer in service.
13 REPLIES 13
@Handy1 wrote:
@JBonnie  try putting your phone to 3G and see if that helps with voice
I could see this helping with the dropped call issue temporarily, but such settings would have zero effect and couldn't fis the issue with callers hearing a number out of service error message.
@JBonnie
does the drop calls issue happens more in specific location?
can you get another phone and test the PM sim there?
if issue persists, please open ticket with PM support
JBonnie
Unable to do that on SE 2nd. generation
JBonnie
Thanks, but reset hasn't solved it so far.
JBonnie
It's the 2nd. generation, but it doesn't show Cellular Data Options
JBonnie
Seem to have full bars. Still dropping calls after had phone reset.
@JBonnie
How many bars are you getting on your phone? You could be in a dead spot where the Telus and Bell towers are too far away.
Check the tower map:
https://www.ertyu.org/steven_nikkel/cancellsites.html?lat=51.998410&lng=-96.987305&zoom=4&type=Roadm...
Ummm... that is a link to send a private message. Meaning there should be no errors. Just saying...   🙂
JBonnie
Thankyou. I’ll try this later. Wasn’t able to get through right now. Just got error message.
@JBonnie  Is that the first iPhone SE or the 2020 iPhone SE . The fist one dosent have volte enabled by PM but the 2020 one does . If it’s the latter try phone set to LTE and try
JBonnie
Thanks but my IPhone SE won’t allow that.
Chalupa_Batman
Hello @JBonnie
If you continue having these issues, you can reach out and send a message to a CS Agent to have them reset your network from their end. You'll need to turn off your phone for this to take effect. Once they've confirmed they've done this, you can restart the phone. This happened to me a while back and once they reset it, no problems.
