06-22-2017 01:08 PM - edited 01-04-2022 01:55 PM
08-13-2018 04:49 AM
Here are 3 possible work-around solutions:
HTH
06-22-2017 04:19 PM
@mimmo is correct, this is the best workaround. With extended absence greeting turned on, callers cannot leave you a message. You could record a brief message asking them to text you instead, or whatever your prefered instructions for contact are.
06-22-2017 03:33 PM
^ this.
06-22-2017 01:38 PM
06-22-2017 01:37 PM - edited 06-22-2017 01:41 PM
