Does the current Black Friday deal for 15Gb apply to existing customers?
acashgupta
I can’t the see option as part of my upgrade options. Also will my loyalty bonuses stay?
please advise how exactly to upgrade.
10 REPLIES 10
Gimli
I will say though - had to read it over 3 times to make sure i wasn't missing anything... kinda like one of those "too good to be true" feelings lol
jor123
Can't go wrong there 🙂
@Gimli
You did the right thing. You won't regret the switch to the new plan, especially if you're paying the same price.
@Dinsdalej
No, with your change to the new plan you won't be forced into the points program.
Just keep getting your same rewards.
Just don't opted into the points program.
@Dinsdalej wrote:
so i just want to confirm that if i change my plan i wont be forced to go to the points model from what i currently have.
Changing plans doesn't force customers onto the points system.
Gimli
I just went into my account - chose the Unlimited Canada wide + 15GB 4G - $40 / 30 days.
I am finally off my Unlimited Province Wide - 12 GB 4G $120 / 90 day plan.
Exact same cost - more than 3x the data and Canada wide rather than province wide.
Thanks PM!
Dinsdalej
The Black Friday offer isn't for 15GB.  The currently advertised offer for Black Friday is a 12GB bonus (which is only for new customers).
will13am
@acashgupta , the option should still be there.  Go to the plans and add-on tab, select 4G plans and scroll to the second option.
walker1
@acashgupta
That deal is for new activation only if you want the black Friday deals.
But you can get the $40 plan with 15 GB data with 4g speed, from inside your account.  Just schedule a change on your next renewal date.
Yes you'll get to keep all your add ONS and rewards with the change of plans.
