09-10-2018 12:40 AM - edited 01-05-2022 01:44 AM
Hey, If I check my voicemail does it use up minutes? Thanks!
10-14-2022 03:55 PM
@Dboxtv4- So you resurrect an old thread and get some suggestions. Then you make another thread and choose a reply as the solution but then go on to give the detailed instructions on how to use the extended absence method that was a suggested idea in the old thread but not the chosen solution here. I know I'm confused.
Maybe an oracle can shuffle things around and apply a valid solution that you seemed to prefer.
10-14-2022 03:04 PM
@Dboxtv4 You can replace the zeros with any Canadian 10-digit phone number. Ie *004*3063370005#
And to go back to Public Mobile voicemail service dial ##004#
10-14-2022 02:22 PM
do we replace 0 with a number or just kep 0000000 and what is the reset number to go back
10-14-2022 02:18 PM
@Dboxtv4 if you dialled *004*0000000000# then dial ##004# to undo it.
Try the voicemail extended absence greeting I mentioned above instead.
10-14-2022 02:16 PM
actually when phone is off then it rings occupied but when phone is on it rings over and over and over then suddenly gets occupied signal
what is code to switch back
10-14-2022 02:12 PM
this os the 1 yes but what is code to add back
10-14-2022 02:10 PM
HI @Dboxtv4 there is really no option to disable voicemail
Some people use the trick to route the call to a number that does not exist:
dial: *004*8080000000#
This calls will ring forever and won't to go voicemail
10-14-2022 02:01 PM
when we do this the phone is pff then itseemsthe phone is not active so we need phone on 24 hours or someone will think they dialed wrong phone---i had bettter before it would just not have option to leave message even when phone is off without seeming like the phone does not exist
10-14-2022 01:49 PM
@Dboxtv4 wrote:what is the number to dia to have no voicemail option
i mean absolutely no voicemail needed
The "best" way to disable voicemail, is to configure your voicemail with an "extended absense greeting", enable it, and then you can set an option to prevent people from leaving messages. This allows you to play your own greeting that tells people that you are not accepting messages and to try again later, or send a text, for example.
This process is described at this link:
Another "simpler" way is to just configure all the conditional call forwards that would normally direct unanswered calls to voicemail, to a dead-end number like 0000000000 - which will just result in an error message, fast busy, or endless ring for the caller if you don't answer. You can configure this by dialing:
*004*0000000000#
and undo it/reset back to public mobile voicemail by dialing:
##004#
10-14-2022 01:46 PM
@Dboxtv4- There is the Extended Absence option where additionally you can not allow recordings to be left. But as this old thread mentioned, the $5 500 minute add-on is great for this plan.
10-14-2022 01:44 PM
10-14-2022 01:43 PM
yes voicemail minutes are used when using check maiil from your phone this is a fact i know i have no minutes so i cannot verify mesage
11-13-2020 05:46 PM
nice ill try that
08-08-2020 12:12 AM - edited 08-08-2020 12:13 AM
With a free YouMail account, voicemails will be emailed to you as attached sound files. 15 free transcriptions to text in the email per month as well. Dont even need to install the app. No need to call into voicemail anymore.
The conditional call forward configuration changes work with Public Mobile -- I use it myself!
08-03-2020 10:42 PM
Use a different phone or use a voip app like TextNow. No minutes.
And get the $5 calling add-on. A terrific value.
08-03-2020 10:41 PM
@sabinefernando9 wrote:yes, i haven't called anyone much but received few voicemails. When i accessed them my munites were going.. Its very dissapointing to see that minutes would go for ur own self service that u pay every month, say 15$ in my case + taxes. Very poor decision from Public mobile to make voicemails as equal as outgoing calls. I just swtiched from Fido 2 weeks back and see this on my usage page?! I don't understand the logic 😒
All carriers consider checking your voicemail from that phone as a regular outgoing call.
08-03-2020 10:38 PM
09-10-2018 03:30 PM
@Dunkgirl wrote:Looks like they changed the way things worked. Or my account is broken. This is what I have found from my testing.
When you call me and I ignore you, 0 minutes used
When I call 611 it does not cost minutes
When you call me and I ignore you and you leave me voicemail usage history says I called 7057804001 and displays the time you were connected to my voicemail (but its free and does not count against 50 minutes- 0 minutes used)
When i call voicemail to listen to your message from my phone it costs minutes (displays instantly on plan details) but does not display ever in usage history
When I call voicemail and even just listen to the menu with no voicemail it costs minutes (displays instantly on plan details) but does not display ever in usage history.
Well done with the testing. I'm saving this for future reference.
09-10-2018 09:59 AM
@Dunkgirl wrote:
@Anonymous wrote:
@Dunkgirl wrote:
@Anonymous wrote:
I gotta brush up on my communication skills 🙂
Having a call that dialed your number that goes to your voicemail costs minutes.
Calling your voicemail from your cellphone running Public Mobile will cost you minutes.
Calling your number from your cellphone running Public Mobile will cost you minutes.
If you can find the voicemail number that the default speed dial #1 goes to and call it from another phone then you would not cost minutes.
Ok thats a little more clear thanks, so even if my phone is turned off and someone calls me and leaves voicemail it uses my minutes?
So if someone bum dials my voicemail, while my phone is off and leaves me a long message I will have 0 minutes left?
Yes. And yes. (assuming you have the $10 plan of course...otherwise why would you be asking)
Does bum dialing still happen?
I seem to recall some tricks mentioned around here to effectively turn voicemail off but I think even just that dialed call costs minute(s).
Edit: This is the recent one I remembered.
Wow, you did an exhaustive test. Can't argue with fact. If this is how the system logs or does not log minutes, never mind what the pundit say.
09-10-2018 09:57 AM
@dna2016 wrote:Hi @Dunkgirl
Just as @stonechucker mentioned, if you gotta go through all this science because of voicemails, maybe the $10 plan isn't the right choice. Highly recommend getting the $25 unlimited talk plan, so now you have no worries, no stress, no panic attacks, no yelling at the other person for leaving you a long message. Plus you can get your monthly cost reduced by getting community rewards, and referral bonuses, plus auto pay credit. Might not take it entirely down to $10 but you can get real close. Or you can go on a 90 day plan and build up your community credits over 3 months. For example, I'm on a 90 day auto pay, so in the last three months I had built up $22 in community rewards, $6 off for auto pay credit, $6 in referral, and $3 for loyalty. If I was on the $25 90 day plan then my next bill would be $42.94 (taxes included), which is technically $14.31/month. Pretty inexpensive and unlimited use, with no voicemail concerns
Just saying there are ways to bring your bill down quite a bit just pay taking part. But if this is for someone who is an elderly, all of the above may not be reasonable, lol.
People on the $10 plan are not heavy users and so it would be economical to buy an add-on for extra minutes rather than paying $15 more each month.
09-10-2018 09:37 AM
Well it looks like you've figured it all out with real observation. I was going by what I understood here from other threads and provided information.
I knew about 611 but you weren't asking about that. And the first ignore is news to me as somewhere here it says that the mere fact of someone calling your number should take the minimum minute. But you've observed otherwise. So all good.
I'm moving to the $10 plan this week so we'll see how it works for my usage.
09-10-2018 09:19 AM
Hi @Dunkgirl
09-10-2018 08:44 AM
The quick answer is if you're on the $10 50 minutes talk and 50 outgoing SMS/MMS messages package, YES, forwarding calls to voicemail (or any other number), and calling into voicemail from your phone will be usage charged calls.
To help with this, the 200 and 400 minute LD add-ons can be used to extend your calling minutes, but outgoing txts will stop at 50.
If you're consistently running out of minutes and txts, the best option may be to upgrade to the $25 plan.
09-10-2018 02:02 AM - edited 09-10-2018 02:10 AM
09-10-2018 01:08 AM - edited 04-13-2019 04:59 PM
(edit: no) Yes. And (edit: no) yes. (assuming you have the $10 plan of course...otherwise why would you be asking)
09-10-2018 01:05 AM
09-10-2018 12:59 AM - edited 04-13-2019 04:58 PM
@Dunkgirl wrote:
@Anonymous wrote:
@Dunkgirl wrote:Hey, If I check my voicemail does it use up minutes? Thanks!
Yes. Even if you call your number to get there. If you call the voicemail number directly however and get into your mailbox then you're golden.
Ok so if someone calls me and I don't answer and leaves voicemail it costs me minutes but if I call my mail box directly its free?
So doing myself is free, but if other people do it I have to pay minutes
Having a call that dialed your number that goes to your voicemail (edit: does not) cost minutes.
09-10-2018 12:53 AM - edited 09-10-2018 12:54 AM
09-10-2018 12:45 AM - edited 04-13-2019 04:57 PM
Yes. Even if you call your number to get there. If you call the voicemail number directly (edit: from another phone) however and get into your mailbox then you're golden.
