08-16-2022 01:28 PM
Hay i can never do this keep getting error ( have done it all incognito and removing cookies and browser history) . And this is the exact same login in as the community so why doesn't it work.
Anyone else experiencing the same thang?
Best thomas
My Account
Service
08-16-2022 06:00 PM
use browser from computer, clear cache and cookies and use one page inPrivate mode,
To Login Page
you need email id and password,
ticket error then contact support team by private message CS_Agent
08-16-2022 05:58 PM
when you porting to PM do you getting SMS from Koodo and you reply yes
if you did then tried turn off device and take out SIM card and reinsert back on, or have other device to tried SIM card in,
if you didn't reply to SMS and open ticket with Customer Support Agent. Chatbot
if open ticket error then contact support team by private message CS_Agent
08-16-2022 03:20 PM - edited 08-16-2022 03:22 PM
Can you try the sim in another phone? Was that Koodo prepaid or postpaid?
Adding - @MadCutomer
08-16-2022 03:17 PM
how to create a post here
i am new to public mobile - trying to activate a sim for my son - porting a koodo number
public mobile has ducted the amount from my credit card and the sim is not activated now i dont kn what to do
08-16-2022 02:30 PM
Try on PC or laptop.
08-16-2022 01:33 PM
I replied in your other conversation. But also, if you know your 4 digit account pin (which you can change in the account) then you can get your remaining data balance from the 611 service. More as another data point.
08-16-2022 01:32 PM - edited 08-16-2022 01:32 PM
@Tbialy wrote:Hay i can never do this keep getting error ( have done it all incognito and removing cookies and browser history) . And this is the exact same login in as the community so why doesn't it work.
Best thomas
to contact a customer service agent try the second method if you are having issues
you will need to open a ticket, to speak to a customer service agent Click here you can check for a response in your community envelope top right corner next to your avatar, or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
