My add on data not working
Tbialy
Hay team,
What to do when add on data don't work,
It's annoying me that it says i have data to use but when I go on LTE it gives me no internet access, i also got a text from public mobile to say I ran out of data. And when I try to submit a ticket it only gives me an error logging in. What should I do..
Best Thomas ( see pics)
1 ACCEPTED SOLUTION
Accepted Solutions
dust2dust
Use the envelope icon up next to your sun avatar and then click on the little pencil icon by the Inbox and then in the to box type cs_agent. It will find it after a few letters and you can select it. Then type a subject, then in the body. They'll ask you some verification questions.
9 REPLIES 9
dust2dust
Can you click on that little spinner refresh button lower down under your promotions usage box.
And maybe the other one under that red bar of plan usage.
See if any numbers change.
Lux
What type of add-on do you have?
If you still have data (check your account, and use the refresh button to refresh the stats), then you can ignore the text message.
If you're getting log-in errors, try using a different browser or using Incognito mode.
Tbialy
Yeah it was as part of a promo bonus 2 GB and it says i have 1.22 left this month but doesn't allow me to change,
Prof my internet not working without wifi:
Tbialy
Jesus sorry didn't want to accept myself just tried to hit replay but thank you guys for helping
So did clicking the little spinner change any numbers? From your images, you appear to be out of plan data but it shows some promo data left. That should work. But if that is also down to nothing then you're out of data. You could buy another gig to hold you over until your next renewal in 6 days.
Tbialy
Yeah it says the same it says i have promo data. But no more of my base data plan, but nothing works, doing a private message to C's agent
Tbialy
Is it just me but the Cs agent login doesn't work for me
 and its not my password cuz i log in to the community using the same password
dust2dust
memorymaze
Following as I’m having exact same issue. Ran out of data on a road trip. I had some left over from promo and bought another gig but I have no data service despite having 1.83 G remaining in my add on.
