Does Xiomi Redmi Note 8 pro is compatible with public mobile network?
vsasidhar
Hi Team,
i am planning to switch to Public mobile network. I am just worried if my phone (Xiomi redmi Note 8 Pro ) is compatible or not.
Thanks & Regards,
Sasidhar.
will13am
@vsasidhar , which model?  Generally, the global models of xiaomi phones will work.  Be careful, some are listed as having global rom which is more to do with language than band compatibility.  If you see band 4 LTE, then it's will work.
gblackma
@vsasidhar according to this link it is https://apn-canada.gishan.net/en/apn/public-mobile/xiaomi-redmi-note-8 . Welcome to PM .
@vsasidhar wrote:
Hi Team,
Thanks & Regards,
Sasidhar.
geopublic
@vsasidhar wrote:
Hi Team,
Thanks & Regards,
Sasidhar.
@vsasidhar  Yes, it will work. Supports the 3G bands (B2 and B5) and also B2, B4, B5, B7 for LTE
