Do I keep $5 off promo if I switch plans?
am10
I currently have the $35/month 2.5GB 3G Plan. There is a $5 off promo and a $2 off for auto-pay/loyalty, so I actually pay $28/month after tax.
If I switch to the $35/month 4G plan, will I still get the $5 off per month promo and pay the same per month?
HALIMACS
Truthfully, @am10 , it's been suggested that switching plans will void any activation promotions which are particular to a plan.
HOWEVER, it's also been suggested by various users that so long as you're not REDUCING the value of your plan, some promotions may be retained.
SO, in your case, you may wish to contact the Customer Support Agents and inquire if you may switch to the desired plan and retain your promotion bonus.
I believe it's worth the ask.
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us,  or
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
Dunkman
@am10
No you will not get the $5 per month credit. You will still keep the autopay rewards.
hycm53
I don't think you will get the $5 off per month promo if you change the plan because the promo is with 2.5GB 3G Plan, but you will still get $2 off for auto-pay/loyalty.
