09-25-2025 06:55 PM
The $15 plan isn't worth it now that the price went up, but I've still got tons of data and minutes left.
09-25-2025 11:27 PM
@hairbag1 wrote:
@funnyhow wrote:The $15 plan isn't worth it now that the price went up, but I've still got tons of data and minutes left.
All plans now have unlimited Cdn wide calling so you'll not be needing or using your add-on minutes. If your old plan had 100 minutes of calling...maybe keep that plan until you use up those add-on mins. Call every PizzaHut in Canada to use 'em up !
@hairbag1 International calling add-ons can still be used with a Canada-wide plan.
09-25-2025 08:18 PM
09-25-2025 06:59 PM
the add-on will stay with you after plan switch
09-25-2025 06:58 PM
yes @funnyhow
add-on and rewards are tied to account, not plan. You will get to keep them
09-25-2025 06:58 PM
You won't lose your add-ons if you switch your plan.
