06-09-2024 10:14 AM
06-09-2024 10:55 AM
If you're porting from Koodo PREPAID, you will need customer support to complete the port process.
This is because both them and Public Mobile share the same systems (all being under the TELUS umbrella of companies), thus you can't 'port' wherein it stays within the same system, just different providers.
If that's the case, customer support is needed to complete the port.
06-09-2024 10:38 AM
Yes
06-09-2024 10:29 AM
are you using the PM app to port over from Koodo?
06-09-2024 10:23 AM
Only online - ticket or direct mail.
It is major PAIN for most customers but nothing can be done...
06-09-2024 10:22 AM
06-09-2024 10:20 AM - edited 06-09-2024 10:20 AM
No worries there. Only a Customer Service Agent can help you with that. Please create a ticket using this link and they will reach out when they can to help you resolve this. Keep an eye on the top right corner of this page for their message/reply.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
06-09-2024 10:19 AM
I can't transfer my number from Koodo. It failed and I can't redo the steps.
06-09-2024 10:18 AM
Unfortunately NO such thing with PM.
All support is on-line through ticket or ask question here and other customers will try to help you out.
06-09-2024 10:18 AM
Hello @Dipak14
I'm sure when you signed up for Public Mobile you read it was a self service provider. There is no phone number to call. These forums are your source for help. There is a way you can message a customer service person but they ask you share your concerns here so we as fellow customers can help.
With that being said, what issues are you having that we can try to help you with?
06-09-2024 10:18 AM
Here is the link for opening a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
06-09-2024 10:16 AM
No there really isn't, PM provides customer support all online through this community and through the chatbot (the orange round circle in the bottom right corner of your screen).
Are you able to share the issue you are having? Maybe the community can help you out
