06-03-2022
03:59 PM
06-03-2022
04:14 PM
Dunkman
I did not receive my $10 credit when i signed onto Public mobile. I put in the referral xxxxxx. They did not receive a
credit either
Edit by Dunkman: removed personal information
Rewards
06-04-2022 07:10 AM
Usually takes up to 72 hours so if yo just did it, it should be showing up soon
06-03-2022 04:27 PM
Did you sign up recently? There is a special promotion for $5/month x 5 month for both parties (new and referer) - until June 6. Maybe you are getting this special promotion instead. Did your friend get a text message saying that he/she referred a new friend?
06-03-2022 04:16 PM
HI @Catbob3 CS Agent can add it check and apply the reward to your account and your friend's
Just open ticket with CS Agent at : https://publicmobile.ca/chatbot.
Follow this to get to ticket open screen quicker:
- Type: My rewards are missing,
- Click on "Public Points"
- click on "Refer A friend",
- click on "Yes, I'm the referred customer',
- click "Click here to submit a ticket" .
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
06-03-2022 04:01 PM - edited 06-03-2022 04:03 PM
@Catbob3 Please remove your code. This is an open forum and the referral code is not supposed to be posted here. Just click the down error and Edit message
You can open ticket with PM support to add the referral code back. You open one single ticket to take care of this for both yourself and your friend:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
