01-26-2026 08:11 PM
I have Submitted transfer number but didn’t receiver any confirmation sms but able to see public mobile network and can use it but incoming messages and calls are not allowing
01-26-2026 08:34 PM
No message from old carrier at all
01-26-2026 08:20 PM
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), you can submit ticket by direct message:
01-26-2026 08:19 PM
You can try porting team for live support , will send you the number private message as we not allowed to post it here
if they are unable to help you need to contact support by
