eSIM cannot installed
Nhanh
I have transferred a new number into my account after I installed the eSIM and now there is no service any more. I like to have the previous number back to my account and activated.
1 REPLY 1
HI @Nhanh remove your phone number from the post, we are just customers here and we don't know to know your phone number
For the eSIM, can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
but if it is not there you will need to ask PM support agent to help, you can submit  ticket by direct message:
