3 hours ago
42m ago
Did you reply to the text from your previous carrier confirming you are porting over to PM? There is a 90 minute window to reply.
If you didn’t reply, your old SIM/eSIM will continue to work until porting is completed.
3 hours ago - last edited 3 hours ago
@Buffoven work with support to get it fixed or ask them to remove credit card info from the account right away so you won’t be charged again
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
